photo shop
Re: photo shop
now the paint scheme matches the wheels, and the Rainbow Towing is perfect! I'd bet Reyy is on his way to W Hollywood!
Re: photo shop
ELADIO you are sooo gay
Re: photo shop
At least my last name doesn't translate to 'KING FLOWERS'
We should print these and post them up at the shop.
Re: photo shop
Now, that's a cute little girly ride there.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
Re: photo shop
eladio, shouldnt you be buying another car or looking for a door instead of painting little girly flowers?
Re: photo shop
I did, I bought this one and brought it over to the shop.
And then I went to look at a couple more on the way home.
Re: photo shop
Nice car Eladio! How does it run?
Ron
Ron
Re: photo shop
Not so well at the moment, it has a a fuel dilevery problem, most likely gummed up fuel injectors. It starts and sounds awesome if fuel is squirted into the intake plenum. It also has an intermitent starting issue, probably the ignition switch as the starter will crank every time the switch is bypassed. The shifter linkage bushings need to be replaced or rather new ones installed as the old ones have fallen appart and the car cannot be shifted.
Re: photo shop
Hot dog! A car you get to work on!
Ron
Ron
Re: photo shop
yeah, he doesn't have enough to do with the 15 cars he has that also don't run and some projects with me
