Is there a explode view of the shifter handle assembly
I do believe that I'm misplacing a peice
Shift handle assembly
Online
Re: Shift handle assembly
This might help
Online
Yes thanks, seems I don't have the number 4 piece, must be a rubber part
I'm not seenning clearly how that bottom piece slids on, it must all go into the top section then u push it on the bottom section? Righ
This is how it looks in the diagram, so it slides in the top section?
What holds that bottom peice on
whoa
Listen man, I just find the info. You cannot expect me to know everything
I have no idea Jim, I am sure those that know will chime in
Online
Lol ok.4uall wrote:whoaListen man, I just find the info. You cannot expect me to know everything
You been great
Well that bottom one has got to be jammed up into it to lock. This is how I see it
I think in my photo, that bottom one needs to go in the other way
You´re exactly right.
That bottom piece is backward on your picture that´s what make evrything so difficult.
- SLOSpider
The middle plastic piece is also backwards. Turn the very left piece around and slide it down the shift shaft. Put on one of the thick rubber bushings next, turn next plastic piece around and slide over lever and push past the lip so those pieces that are cut will snap to the lip just below the to of the shaft. Next put the next big rubber grommet on then the top rubber cap.
You also want to be sure there is no OLD rubber pieces stuck up inside your shift tube ( the chrome shaft your shifter ball is on ). Once you clear that then slide it down on top of all those pieces you just put on. Pushing down you want to work the bottom plastic piece up into the rib you see on the bottom of the chrome housing to lock everything together.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Online
Thanks, I got it on
- SLOSpider
Good, I re read and typed right instead of left but now corrected for future readers
1975 124 Spider
- hayesbd
- Your car is a: 1973 Spider
I just did this on my car and followed the shop manual instructions. They simply tell you to assemble all parts into the hollow shift rod (item 2) in the order that Brian mentioned, including the lower plastic clip. You then simply push (hard) it into place on the lower shift rod until you feel it click. Worked like a charm! I put a bit of silicone grease on all the parts to ease assembly, but it does make the rod rotate very easily (some may not like that).
Hope this helps.
Brian
Hope this helps.
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
Online
Thanks peeps
Got it on
Got it on
- SLOSpider
hayesbd wrote:I just did this on my car and followed the shop manual instructions. They simply tell you to assemble all parts into the hollow shift rod (item 2) in the order that Brian mentioned, including the lower plastic clip. You then simply push (hard) it into place on the lower shift rod until you feel it click. Worked like a charm! I put a bit of silicone grease on all the parts to ease assembly, but it does make the rod rotate very easily (some may not like that).
Hope this helps.
Brian
I need one of those manuals. Never thought to put it all together and try it. But my shifter is out so Ill give it a try when it goes back together. I usually remove that stuff and force it down lower on the shaft to get that short shifter feel. Works for me until someone gets in your car thinking the have to pick up the handle to get it in reverse and there left holding it in there hand
1975 124 Spider
