the pumpkin
the pumpkin
is there such thing as a bearing at the yoke, going bad and possible cause a viberation and a certain speed
Re: the pumpkin
if i take my hand and push up on it, it moves, should it ?
Re: the pumpkin
No. Pinions should not move up and down. That said, pinion brgs not generally cause of vibration.
Re: the pumpkin
it not caused?
- seabeelt
- Patron 2019
Re: the pumpkin
If the bearings are bad, more than likely so is the seal. Is it leaking?
Re: the pumpkin
in checking it out more, the center hanger bearing is bad, and the flex is bad and u joints
that why it vibrates
- maytag
Re: the pumpkin
uh-yup.... that'll do it! Every time!fiat218 wrote:in checking it out more, the center hanger bearing is bad, and the flex is bad and u joints
Re: the pumpkin
parts are on the way
so it will be good
maytag. how far are u away from lincoln cali
u need a job getting a car
Re: the pumpkin
Should there be any play in the center joint or shaft end? Where is the flex joint located, front or rear? I also have a vibration at speeds over 50 and plan on getting under mine for the first time this weekend.
Anything else I should look at while I'm under there?
Jeremy
Jeremy
Re: the pumpkin
FRONT124Germ wrote:Should there be any play in the center joint or shaft end? Where is the flex joint located, front or rear? I also have a vibration at speeds over 50 and plan on getting under mine for the first time this weekend.
Jeremy
http://www.international-auto.com/drive ... joints.cfm
Re: the pumpkin
what would be the ratio on the 69 stock rear end, and how would u know what it is from just looking at it or u have to count the revalutions, spelling
- tartan18
Re: the pumpkin
I found this somewhere on this Forum so I can't take the credit.fiat218 wrote:what would be the ratio on the 69 stock rear end, and how would u know what it is from just looking at it or u have to count the revalutions, spelling
If your differential is not stenciled (as mine was not), you can measure the ratio pretty easily. Jack one side of the rear so that one wheel is off the ground. Block the wheels on the ground to keep the car from rolling. Release the parking brake, and put the tranny in nuetral. Mark the driveshaft flange in reference to the differential case. Mark the lifted rear tire in reference to the ground. Spin the lifted wheel exactly 1 turn while counting turns of the driveshaft. The result is exactly 1/2 of your differential ratio.
So, if the driveshaft turns about 1.75 turns (90° shy of 2 turns), then your rear end is the automatic 3.58:1 ratio.
If the driveshaft turns almost 2 turns (1.95 turns, or 20° shy of 2 turns), then your rear end is 3.9:1.
If the driveshaft turns slightly more than 2 turns (2 turns + about 20 degrees) then your rear end is 4.1:1.
If the driveshaft turns about 2.15 turns (2 turns + about 55 degrees), then your rear end is 4.3:1.
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
