Front spoiler on a 1980
124cso
Post by 124cso »
The front spoiler / air-dam was missing from my car when I bought it and suspect it was wrecked at some point. Judging from the dents in the sump, the car has "grounded" at some point.
Before I order a new spoiler, can someone with a similar car (heavy tube bumpers & std 13" wheels) measure the distance from the ground to their car's spoiler on level standing ? I live in an area with "mountable kerbs" and want to be sure I can get in and out my own driveway first.
Thanks in advance
grittracing
Re: Front spoiler on a 1980
Post by grittracing »
I would love to help with that but i have 15 wheels sorry
124cso
Post by 124cso »
grittracing wrote:I would love to help with that but i have 15 wheels sorry
Depends what profile the tires 50/60 ? As long as I know I can probably work it out.
124cso
Post by 124cso »
Some must own a spider with a front spoiler AND a tape measure ?
I would certainly go out right now and measure for you, but my spoiler is missing too! A new one just arrived in the mail yesterday and is going on when the weather clears. I can get you the distance to the mounting edge if that helps.
Pete
JammerX19
Post by JammerX19 »
RRoller123 wrote:I would certainly go out right now and measure for you, but my spoiler is missing too! A new one just arrived in the mail yesterday and is going on when the weather clears. I can get you the distance to the mounting edge if that helps.
Pete
Where did you get the spoiler? I could use one as well.
Jody Farr
'74 124 Spider
'12 Fiat 500 Prima Edizione #13
divace73
Post by divace73 »
get the spoiler of Mark allison >>Click here for his website<<, (he also runs this forum) that is where I got mine from
Have you lowered the spider at all? I have and have 125 stub axles, the measuremnt may be pointless. I have also installed an Argenta sump (also have it baffled) to avoid the common problem of the ice cream container 2 L sump
How did you go with the fuel pump??
Also check out brad's web site http://www.artigue.com/fiatcontent/book ... 124_MM.pdf all CSO owners should have copy of this, it list the bosh number as Fuel Pump
P/N 0 580 464 019
Cheers David
see my >>You tube channel<<
CajunMike
Post by CajunMike »
8" from floor to bottom of spoiler. 1979 tube bumpers stock suspension, 165X13 tires on stock steel wheels. It is the original factory spoiler.
@JammerX: I got mine from Autoricambi, (new) but all the vendors seem to carry them. Haven't opened the box yet, but everything I have bought from them has been well packaged and shipped quickly.
Pete
courtenay
Post by courtenay »
Mine is 8" from the floor. Note the lower valence is 101/2 inches from the floor, so you lose about 21/2 inches of clearance with the spoiler. Got mine from Allisons.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
81SPIDERMATT
Post by 81SPIDERMATT »
bump not to hijack ... seemed like the most current spoiler thread... how is everyone attaching the spoiler.... thanks... Matt
It shares the hardware with the front end splash shield, I will take a pic a little later and post it.
81SPIDERMATT
RRoller123 wrote:It shares the hardware with the front end splash shield, I will take a pic a little later and post it.
thanks
124Germ
Post by 124Germ »
What about installing on a '72 that never had one? Can it be installed or is there too much custom work required?
Jeremy
The bolts go into threaded holes, but some were stripped and I had to put nuts and lockwashers behind them. Not sure if the original holes are nut plates, welded nut, or just threads in the metal or whatever. I also extensively modified the splash shield so that you don't have to take it (and the spoiler) off to get to the oil filter. Here are some pics:
