Fuel tank seal
JConnerly
Fuel tank seal
Post by JConnerly »
I have removed my fuel tank to cleán up some corrosion and need to replace the gasket that goes under the flange, between the tank and the trunk floor. Any suggestions on replacement material?
124JOE
Re: Fuel tank seal
Post by 124JOE »
just did this one mine
i used a window seal
a closed cell sticky foam
JConnerly
Re: Fuel tank seal
Post by JConnerly »
I was considering that approach. I also was sneering about plumber's putty.
JConnerly
Re: Fuel tank seal
Post by JConnerly »
That would be wondering, not sneering. It's too early.
narfire
Re: Fuel tank seal
Post by narfire »
I used window seal as well
jimincalif
Your car is a: 1980 FI Spider
Re: Fuel tank seal
Post by jimincalif »
1980 FI Spider
124ADDHE
Re: Fuel tank seal
Post by 124ADDHE »
roof tar, window caulk, weatherstrip, W.H.Y. thats laying around the house and is cheap :)
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
htchevyii
Re: Fuel tank seal
Post by htchevyii »
I'd be worried about that stuff holding up to fuel. I found this site that sells all sorts of gasket material and only Fluoro-
elastomer and Nitrile seem so be safe for gasoline.
http://www.allstategasket.com/info_specs_01.asp
under: Gasket specifications guide, select chemical resistance.
http://www.allstategasket.com/chem_res_cht.asp
Trey
boogiedude
Re: Fuel tank seal
Post by boogiedude »
htchevyii wrote:I'd be worried about that stuff holding up to fuel. I found this site that sells all sorts of gasket material and only Fluoro-
This seal only seals the outside of the tank, and the body of the car to keep fumes and such out. It doesnt contact gasoline unless you've got a leak in the tank or line back there. And thats a whole other can of worms
DocGraphics
Re: Fuel tank seal
Post by DocGraphics »
I used 3/8" X 3/4" rubber foam weather stripping from ace. Figuring if need be it would hold up to any spilled gas.
Looks mainly to be there to seal out water & fumes from the trunk.
The stuff there from the factory was just a foam gasket from what I can tell from what I removed.
Don Raugust
124JOE
Re: Fuel tank seal
Post by 124JOE »
yes they used a foam
i wouldnt glue it in with any caulk or puddy
just be sure the flanges are flat and straight
my forward section was bent down now its not
and its sealed
JConnerly
Re: Fuel tank seal
Post by JConnerly »
Thanks for the replys. Now if I can just get the tank back from getting it sand blasted.
manoa matt
Re: Fuel tank seal
Post by manoa matt »
"Now if I can just get the tank back from getting it sand blasted."
I hope they only blasted the outside of the tank and capped all holes/ports. The tank has internal baffles and the sand will be extremely hard to get it all out. Not sure how they would even sand blast the inside anyway. Most tanks are boiled out at a radiator shop.
