Build the image in your favorite program then print on photo paper. Let dry then cover the image face with transparent self adhesive plastic. On the back side use a quality double sided tape and get 100% coverage. Cut around the perimeter. Peel off the double sided tape backing and carefully place using your thumb to carefully put in position. The only issue is will they last?? If not at least you can make a replacement.
