We'll maybe that's a little (allot) exaggerated.... but it looks cool
Rick
kmead wrote:Like the plywood. Now you not only have to worry about the tin worm, but also termites and carpenter ants.
Watch for little tunnels coming up the tires and along suspension parts leading to the base mount.
I have done that before (more than once actually)So Cal Mark wrote:I hope you remember to plug the AFM electrical connector back in, or you won't be going anywhere
The flat light blue object the AFM and the filter are attached to look like plywood in the pics. It was a joke that clearly fell flat.Foster48x wrote:kmead wrote:Like the plywood. Now you not only have to worry about the tin worm, but also termites and carpenter ants.
Plywood? Did I miss something?
