Yes another question about carb swaps.
I have a new 34ADF in the box I was saving for a 79 that I was close to buying.That has'nt panned out but I do have a 72 that I could use it on next year if the carb will swap without too much fiddling.I have a single plane manifold as well.
Will the 34adf bolt on or is it going to be for sale? Thinking the 72 has manual choke.
Thx
Chris
carb swap
Re: carb swap
I may be interested in both the carb and the intake manifold if you determine you won't need them. Thx.
- manoa matt
Re: carb swap
Is the single plane manifold currently on the car? The 72 anifold will not have the coolant port at the rear of the manifold for the automatic water choke on the 34 ADF.
Re: carb swap
Hi Matt.
The manifold on the car I want to change carbs is a stock duel plane with a stock carb found on the 72. The single plane I bought has a port that has been pinched off,something to do with smog is my guess and a smaller port with two plugged lines from the "T". In front of the carb is a fitting with 2 small ports comming from a single fitting (they are plastic I think)
Can the single plane be rigged to flow water to the choke on the carb?
I am a while out on this,but if it ain't gonna work I could use the loot for another carb that will offer a bit more performance than stock.
Re: carb swap
water choke started in ??1975??
are you asking to modify a '74 or older 1800 manifold to a water choke? you'll need to tap into the existing water jacket of the intake manifold and thread that hole for a port (feed tube) about the same size as the tube on your water choke. i do not recall hearing of anyone that has actually done this.
then there is the question of the other tube on the exhaust side of the engine for the return line from the carb back to the water pump. does the heater pipe from the water pump on your car have this port for the water choke?
- ga.spyder
Re: carb swap
Chris,
I would definitely be interested in the carb if you decide to sell it.
Craig
Craig
Craig Nelson
Fling It Around Turns !
Re: carb swap
Dang I hate that.Try to post same time as another come through.
Anyway, try again,I had bought a single plane sometime ago,It looks to have a water port on the side closest to the fire wall,goes to one side of the water jacket on the carb? As for a return line,could one plumb into the 2L heater pipe with the port on it. I think the heater pipe from my other 72 did not have a port on it.
Please try to excuse the ignorance,I've been mucking about with a FI for the past two years and this carb stuff is a bit of a learning curve.
I'll let all know if I sell the carb,but if I can get water to it and out of it it should work.
Chris
Chris
- ga.spyder
Re: carb swap
I know the feelin',Chris.After getting to know the Bosch f.i. system,all of the sudden I have a carb to look after.The last carb I worked on was in shop class ...in High School...a very,very long time ago
Craig
Craig
Craig Nelson
Re: carb swap
Craig, all I could think of when I first took the air cleaner off the carb was " now there are two more holes to drop stuff into"
