77 Fiat 124 - Transmission Output Shaft Leaking
- Your car is a: 78 Fiat 124
The output shaft is leaking on my manual 5 speed. I've read the manual, watched, the videos, etc. I understand the process and it looks easy to do, on a bench or if you have a lift (which I do not). I really do not want to pull the transmission to do this. Given that I can only get the car so high on jackstands, can this be done fairly easily with limited space? Besides the obvious stuff (mind the Guibo
) are there any other challenges that come up with trying to do this "In vehicle" ? Thank you.
