Exhaust Downpipe Sealer?
RXTbone
Your car is a: 1980 Fiat 124 Spider 2000
Post by RXTbone »
1980 2000 - Noticed there's a gasket that's available with a description that says the downpipe flange did not come with an OEM gasket. Are these normally sealed with just sealer? Thank you in advance for the help!
Kansas, USA
Re: Exhaust Downpipe Sealer?
Don't use sealer, and none was used originally. Flange to flange connections should be fine, and some people add a gasket although it's not always necessary. A gasket helps if your flanges aren't completely flat, though.
