How to remove Door Lock Assembly?
Posted: Thu May 18, 2023 9:37 pm
Hi there
My current goal is to get the door lock cylinder out to get it rekeyed; I decided to take out the entire door lock assembly to get at it. However, I'm stuck on removing two pieces:
One is the plastic piece on the side of the door that connects to the body of the car when the door is shut and is on the end of the door lock assembly.
The second piece is the link arm from the lock cylinder to the door lock assembly; I have no idea how to get this off, little bugger doesn't want to budge every way I have tried, and before I can yank the whole assembly out of the door, it looks to be needing to be removed.
I've been following the manual on the removal of all this, the highlighted portions are the ones I'm having issues with. I cant even find the plastic piece its talking about on the door link arm.
I appreciate any help you can provide.
