79 2000 stripped water pump bolt
barnesjtsl
Your car is a: 1979 Spider
Post by barnesjtsl »
Anybody ever strip a water pump bolt? If so, what did you do?
barnesjtsl
Re: 79 2000 stripped water pump bolt
Did the bolt break off, or are the threads stripped? If the threads are stripped, do you know if it's the female threads in the block or the male threads in the bolt that are stripped? Or both?
barnesjtsl
Turns out the bolt broke. Took off the fuel pump and there was about 3/16 of an inch of bolt sticking out. Easily removed it.
