1983 124 FI spider starts but won't accelerate
- Your car is a: 1983 pininfarina
I Have a 1983 124 spider. It starts and runs at idle but it won't accelerate when I depress the throttle. Any suggestions will be appreciated.
Re: 1983 124 FI spider starts but won't accelerate
A plugged up cat will cause this problem. So if you still have the cat check that first.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
- Your car is a: 1983 Pininfarina
Have you checked the distributor spark advance with a timing light?
