79 Fiat Spider 124
Italfiat79
Your car is a: 1979 Fiat Spider 124
79 Fiat Spider 124
Post by Italfiat79 »
I recently bought a 79 Fiat last fall and I’m debating what to to for the crossmember issue. There is a hair line crack which needs to be fixed to pass inspection. So I’m wondering if I should get it professionally welded with a bracket or should I attempt replacing it.
If I decide to replace it, does anyone here have the experience removing the crossmember without pulling the engine out? Thank you, Mike
Re: 79 Fiat Spider 124
Contact wetminkey on this site, as he's dealt with this before. See: http://www.fiatspider.com/f15/viewtopic ... er#p299772
Also suggest posting this question in the technical area as it will get more views.
Italfiat79
Hi Bryan,
Thank you very much for your help, much appreciated!
Mike
