Left Turn Signal
WUFFIAT78
Your car is a: 1978 124 Spider
Left Turn Signal
Post by WUFFIAT78 »
Good day all, I recently bought a 78 124. When I purchased the car the left turn signal worked fine. After taking the car out to dinner on the way home it would no longer go into the turn position. It is like there is a bind preventing the left turn signal. The right turn signal moved properly.
Thoughts?
Thanks in Advance.
Dwayne
TX82FIAT
Re: Left Turn Signal
Post by TX82FIAT »
Check the position of the turn signal mounting under the plastic cover on the steering column in relation to the steering column. If the turn signal attachment moved it could be you are caught on the plastic housing. if that is not the case, you can diagnose the mechanism with the cover off to see if something else is in the switch or interfering.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
