Idler box filling
sweet124
Your car is a: 1980 FI 124 spider
Idler box filling
Post by sweet124 »
Is it ok to fill the idler box off the car.and the steering box they where removed during the on going restoration.
1980 fiat spider under restoration
Re: Idler box filling
Yes, that should be fine, although I wouldn't store them upside down or on their side.
sweet124
Post by sweet124 »
What is the fill level for the idler, I read 3/4 below the fill plug on the steering box but can’t find anything on the idler fill level
The idler box is pretty much filled all the way up with oil, but you have to be a little careful as there are two "chambers" inside the box. The bottom one has the vanes that provide the resistance while moving through the oil, so that should be filled. The top chamber has only a small amount of oil in it. There is a separator with ball bearing one-way valves that allow oil to go from the top chamber to the bottom chamber.
If you haven't removed the top cover and the middle separator plate on your idler, this should be done is the whole thing gets gummed up over time. It can be done with the idler in the car, but you've already got yours off the car.
By the way, I'm assuming you have the hydraulic idler. Some models used a friction damper, as well as aftermarket versions, and those don't require oil.
sweet124
Post by sweet124 »
Yes I disassembled completely and clean out the black gunk and replace the two o rings.I was surprised to see oil in it.
