80 FI manual part?
greenspider
Your car is a: 1980 Spider 2000 FI manual
80 FI manual part?
Post by greenspider »
For 1980 FI manual Spider, does anyone recognize where this goes? Clutch cable related perhaps? Thanks
Re: 80 FI manual part?
greenspider wrote:Image
That's an odd part, GreenSpider. I don't recall seeing it on any Fiat that I've worked on recently... But, maybe I'm missing something from the later model years.
DieselSpider
Post by DieselSpider »
Something to put it into size perspective would be nice. Could be a wire or hose support missing its grommet.
DieselSpider wrote:Something to put it into size perspective would be nice. Could be a wire or hose support missing its grommet.
That's kinda what I'm thinking too. The attachment point is the circular hole towards the top left, and the two C-shaped prongs to the right and left are supports for hoses or cables/wires.
Post by RRoller123 »
Some part of the convertible top mechanism?
greenspider
All clean if that helps. :idea: The square notch appears to keep it from turning. The round end looks to fit a rubber grommet but it has a small lip. Stand off to keep the e-brake cable from touching the exhaust pipe, or ???? Just grabbin' for straws now.
DieselSpider
Throttle cable support or ignition wire loom? Perhaps fuel line support? It looks too clean and rust free to have been under the car and is a bit small for a heater hose.
