Transmission mounting dimensions needed for unusual engine swap.
BammBamm
Your car is a: 1982 Pininfarina Spider
Post by BammBamm »
I need to get the transmission dimension from engine mount hole to mount hole And dimension to the input shaft. A friend gave me a Honda J35A4 engine (3.5l -260hp). It looks like it will fit so I need to make a adapter plate, modified flywheel and flywheel spacer. Once I have good dimension, I can have t he adapter and spacer water jet cut and the flywheel machined. Anybody have some factory drawings?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
