first step of constructing the bike carb manifold is complete. I will be running Keihin CVK carbs from a GXSR600.
Next up once the flanges arrive will be to weld on pipes to accept the carburetors, drill and tape one of the runners for the brake booster vacuum/dizzy advance. Then bolt it all to the engine and build a throttle cable. That's pretty much it, actually
Cheers
Steiny
P.S: Seeing as the laser cutter spat out two of these, I'll have a spare. Let me know if you're interested.
