Fuel seeping from Weber mixture screw.
MIGHTY 8
Your car is a: 1980 Spider
Post by MIGHTY 8 »
Hi,
Noticed a seep (and Occasional drip) from 3 mixture screws after driving car. Last one towards the rear was perfectly dry.
I also noticed that after starting the engine, the problem corrected itself on two of the three mixture screws after running for a few minutes.
Any help greatly appreciated
Nut124
Re: Fuel seeping from Weber mixture screw.
Post by Nut124 »
Replace the O-ring on the screw shank.
Nut124
sptcoupe
Your car is a: 1972 124 Sport Coupe
Post by sptcoupe »
Check you float levels, and make sure the fuel pressure is regulated at 2.5psi.
sptcoupe
Post by sptcoupe »
And while you have the carb tops off, check the size of the needle valves (should be 175 or 200), and make sure they move freely.
