Can't figure out what just happened...
Vandrid
Post by Vandrid »
So today I go out to check my fluids, look at my spark plugs, clean the engine a little, just a quick check before I take out the car. Found a bit of oil on the top of my air filter housing. I decided to take a look at the air filter and found oil in my air filter area... next I found brass shavings in the filter housing. I have no clue what happened and don't know what they are, or how concerned I should be. Can anyone identify what is happening?
https://pasteboard.co/GFvjkmj.jpg
Dave-O Supreme-O
1979 Fiat Spider 2000 "Fiona"
brackie1
Your car is a: 1978 124 spider
Re: Can't figure out what just happened...
Post by brackie1 »
That really weird, never seen anything like that. However, I would love to know how to use pasteboard that you used to post the pick.
Gene
North Carolina
Post by RRoller123 »
The oil is probably coming up through the breather tube, but the brass shrapnel, that is odd.... Mice? Cover hold down screws damaging brass inserts? Very odd. Multiple pieces that large would not likely be carried up the breather tube.
blazingspider
Your car is a: 1977 fiat spider
Post by blazingspider »
The big breather hose has a flame arrester inserted into it. I wonder if those bits you found are from it breaking apart. You should check that hose and take a look inside.
baltobernie
Post by baltobernie »
That sure looks like the source! I guess large pieces CAN be carried up that tube. Surprising to me.
DieselSpider
Post by DieselSpider »
Did we have a back fire event while starting one day?
fiat218
Post by fiat218 »
:shock:
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
Vandrid
Post by Vandrid »
Found out it was the spark arrestor. The crankcase hose was worn from wear and age letting air in the hose and blowing oil and the arrestor out in the air filter housing. That's my theory at least. I'm now replacing that hose as well as a mirriad or other parts. I'll let you all know how it goes
Dave-O Supreme-O
TwinFast
Post by TwinFast »
I replaced this hose few months ago without the flame arrestor. The mechanic told me that puting it in it's just adding problems. Hope that i do well
Fiat 124 Spider 1.8L 1978
Jaguar XKR 4.2L 2009
Harley Davidson Fat Bob 96Ci 2011
joelittel
Post by joelittel »
TwinFast wrote:I replaced this hose few months ago without the flame arrestor. The mechanic told me that puting it in it's just adding problems. Hope that i do well
I'm doubting this is true and I'd bet it's an easy bit to install should you decide to do so.
It probably collects some oil mist as well and helps keep it from getting up top.
Vandrid
Post by Vandrid »
Fits right at the top of the tube and you just push it in. Done. I think mine was under $3 on autoracambi
Dave-O Supreme-O
