On my '75 Spider, there is a receptacle under the driver side dash for a bulb. The electrical diagrams call it an "inspection bulb".
Would anyone know the specific bulb type/number that I could find at the local auto parts store?
Jeff
Inspection Bulb
- AndyVAS
- Your car is a: 1980 Fiat 124 Spider
Re: Inspection Bulb
If I remember correctly, it isn't for just a bulb. It is the plug for a wired light. I've never seen one but it's what I heard of.
Andy Phillips
Vick Auto - Technician, Performance Engine Builder & PFI Developer (with ITBs)
http://www.vickauto.com
- Your car is a: 1975 spider
Re: Inspection Bulb
It looks as if it is a receptacle for a bulb, one that would just be pushed in. Similar to a turn signal bulb for instance on a modern car.
Re: Inspection Bulb
I believe it's the same as all the instrument cluster bulbs...If I'm thinking of the right one, it slides into a cylindrical connector with "wires" coming out. These are plastic fibers that transmit the light to the heater controls to light them up in the center console by the e brake...
Re: Inspection Bulb
PhillySpider,
I know which one you're speaking of and this is different. It's under the dash, driver side, close to the fuse box but slightly behind it.
I'm just going to experiment with some old bulbs when I get home and see what works.
Thanks anyway, not a big deal really.
Jeff
Jeff
Re: Inspection Bulb
It may have been an accessory but I have seen pictures of a light on a cord that plugged into that socket. I've never seen one in real life.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
Re: Inspection Bulb
I think VAS is correct. There was actually a light on the end of a long cord and the other end plugs into that socket. I know I've seen a picture of one but I've never seen one in real life.
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
Re: Inspection Bulb
deleted redundant post
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
- Your car is a: 1981 Spider Turbo - missing the turbo
Re: Inspection Bulb
Yes - do a search it's a light, cable and connector that plugs into the socket under the dash, comes in a metal case. There are photos somewhere on the forum.
THE FLEET
2014 Abarth "SS"
1981 Spider 2000 (Legend Industries Turbo - minus the Turbo)
1978 X1/9 1.3 Dual IDF 40's, Coupe Cam, Allison Header/Exhaust
1971 128 Sedan 1100cc, Coupe Cam/Headers
Motokhana Special 127 rear engined Rail 903cc
2014 Abarth "SS"
