1983 spider fuses diagram
lucas83
Your car is a: 1983 Fiat Pininfarina 2000
Contact:
Post by lucas83 »
hey guys looking for the fuse diagram for an 83 spider, the manual shows every year except 83. The second fuse from the door keeps popping and the rpm, fuel, temp, oil pressure gauge stops working. this just started happening since I put my engine back in this year
Re: 1983 spider fuses diagram
The library in https://www.mirafiori.com/forum/viewtop ... 73&t=96357 (you have to be a member to view library) has a 1985 owners manual and 1984 wire diagrams. They may help you as they are probably very similar to a 1983.
On the bottom wire terminals (behind fuse panel) there is more than likely more than one terminal with wires on them. Removing the wires one at a time will help isolate the cause of the fuse blowing. The wires are colored and the colors are shown in the wire diagram. What circuits are on each fuse is shown in the owners manual.
aaalbedo
Post by aaalbedo »
1984 pininfarina, Honda S2000 seats, daily fair weather driver
2006 BMW 330 CIc, sensible winter convertible
