Radiator Fan Switch Replacement Question
donerehart
Your car is a: 1976 spider
Post by donerehart »
Hi Spider Team,
I need to replace my radiator fan switch on my 76. Is there a way to do that without draining all your anti-freeze? Any tips for this?
Don
76 Spider
St. Louis, MO
fiat218
Re: Radiator Fan Switch Replacement Question
Post by fiat218 »
unscrew and screw fast :)
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
Post by RRoller123 »
Gunna have to drain it I think, no way I know of to get around that.
I think if the radiator cap is sealing correctly and the engine is cold you should be able to remove the cooling fan switch and replace it with very little coolant leaking out. There should be no way for air to enter the system if the radiator cap is good so almost no coolant will should come out. Like putting your finger over a straw.
Nah, the hole is too big, air leaks past. The surface tension can't stop it.
klweimer
Post by klweimer »
Maybe if you flip the car over on it's top, so the fan switch is at the top of the system? :D
fiat218
Post by fiat218 »
you could unscrew that plug quick and get a new one in there before a quart comes out. i will bet on that
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
JohnMc
Your car is a: 1970 Fiat 124
Post by JohnMc »
drain into a clean container and put back in.
DieselSpider
Post by DieselSpider »
When I faced this quadry the additional issue of how much torque would be required to unscrew the original switch potentially damaging the lower radiator pan causing leaks became a concern so I purchased the external adjustable universal switch from Advanced Auto Parts for less than $20 and just bypassed the original.
Most stores don't realize they even have them in stock but can find them on the shelf out back. I strapped the sensor to the upper radiator hose with a few zip ties since I did not want to chance causing a leak when pushing the mounting straps through the fins in the radiator and it works just fine. Added the Lucas version of Water Wetter to the coolant while I was at it and have no problems even when roadway temps are closing in on 120 degrees.
