Transmission and Gear Oil Change
profcucchi
Your car is a: 1979 Fiat 2000
Post by profcucchi »
Hello All,
Am I missing something here?
I looked through my Brooklands book and changing these fluids seems too simple.
Unscrew the filler, unscrew the drain. Watch out for hot fluid.
Drain for a while, then refill to the bottom of the filler screw.
That's it? And people pay for this?
CCucchi
1979 Fiat 2000 "Luigi"
Re: Transmission and Gear Oil Change
Post by AriK »
Raising the car making it level is most of the work, o/w yes there's nothing to it :)
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
Just be sure to use the right oils. Regular gear oil in the rear end, GL1 in transmission.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
4uall
Post by 4uall »
profcucchi
Thanks everyone.
I bought the fluids yesterday after going through various threads/opinions.
I settled on Royal Purple 75w90 and Redline MT90.
Now I just need some warmer weather - wet snow yesterday...
profcucchi
Finally getting these fluids changed, tomorrow.
From Royal Purples website:
"Max Gear is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. It is non-corrosive to soft yellow metals (brass, bronze, copper, etc.) and synchronizer safe. Specially designed to extend gear and bearing life, Max Gear provides superior corrosion protection over competing conventional and synthetic gear oils."
Started sweating it's use in the last couple of days.
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
It's not just the bearings you need to watch out for. The GL1 is VERY sticky.
OttawaTom
Your car is a: 1976 Fiat 124 Spider
Post by OttawaTom »
Here's an interesting read about gear oil, EP and what it does to yellow metals, though it's talking about a Corvair transmission.
http://www.widman.biz/Corvair/English/L ... saxle.html
I still went with the GL-1 though...
