I didn't know brake fluid was actually flammable to be honest! I had always heard it was glycol based so I assumed it was like antifreeze. That's why it replaced alcohol as a coolant back in the 1920s or 1930s because it wasn't flammable.
Years ago every now and then the parking brake cable would hang up on the driver's side. A quick jerk would cause it to release. Then for no apparent reason, I haven't had any issues with the parking brake for years.
The weird thing is this same thing happens to my Trabant on the same side if the car sits for more than a few days with the parking brake engaged. So I'm trying to "break" me of this habit!
With both cars, if one of the rear brakes is sticking, I can definitely feel a loss in power. You would think the guy driving the car would have smelled burned brake lining before it actually caught fire.
Speaking of brakes but a different type of vehicle. I bought a 1997 Polaris Xplorer 300 for $950 a couple of months ago. I couldn't justify spending more than $1000 on a "toy" that I could not legally drive on the road.
I excepted I would need to do some work to it but had no idea the brakes were in the condition they were in. When I tested this thing, it was pouring down rain and the brakes seem to work fine on it. After pulling the front wheels off I discovered someone had ran the pads down to nothing. Literally.
On one side the outer backing plate was paper thin and on the other the backing plate had worn down to the point it fell off so the fingers on the brake caliper were rubbing against the rotor. So I ended up have to replace both calipers. The rear center caliper on the drive was down to the metal but luckily not as bad as the fronts so I was able to save the rear caliper. Surprisingly, I measured all three rotors and they were still in spec!
