I have a tiny, weepy oil leak at valve cover gasket. My plan was just to remove cover; clean up surface; use some hi-temp gasket maker.
Question:
1) does valve cover simply come off by removing the two thumb/hex centered screws?
2) what are the other things on the cover: there seems to be a threaded stud that has nothing on it; and there are some "holes". When I take off over will it be obvious?
Below is picture:
The thumb/hex centered screw is roughly in middle of photo. The stud is at 5:00 (almost head on to camera) relative to thumb screw; the hole (filled in with screw?) is at 7:00 relative to thumb screw.
