There is a smallp iece of trim the runs below the rear side glass windows (between the window ad the body) It has a rubber seal with it.
Well, the other day I opened the passenger door and this piece of trim was sticking straight up in the air. Apparently it is only connected because the trim piece sits tightly on the body beside the window. There appeared to be a couple holes in this trim. I was wondering, can anyone tell me how this is supposed to be attached to the car? The holes made me think there might have been rivets, but couldn't tell. It has never popped up before, but it came up and off so easily that I assume it's been like that since I got the car about a year ago.
Thanks!
Rear-side window trim
- Your car is a: 1977 Fiat 1800
- Your car is a: 1980 spider 2000
Re: Rear-side window trim
It just presses on tight to the body flange. Problem is, if not secured tight, the trim comes up when the top is raised due to window/glass/rubber binding against each other.
Thanks. I guess I'll just have to keep an eye on it. I assumed there had to be something holding it down, but I guess these cars are full of surprises.
