I have a new top from AR and I am looking at having it professionally installed Before I venture down the path of woulda shoulda coulda I wanted to know what the thoughts and opinions were in regards to timelines, if I should prep prior to install, etc etc Currently $85/hr. If anyone is reading this in the Ottawa area looking to have it done this month prior to Montebello event so feel free to suggest locations if you have had good experiences, thanks
I was looking into this and the gypsy installers will do it in 4 hours at your location while they case the.... any ways they provide the top for the same prices as a 6 year Rollins and then charge $1,100 for the installation giving you a 2 year warranty on the top. Brick and mortar establishments keep the car for two days minimum and do all the basic prep and installation for $800 including the Rollins top with a 6 year warranty. The two days is to allow the top to stretch out and make any adjustments before it leaves their shop.
I am currently brushing up on my welding skills in case the front bow needs any attention and have a new top kit waiting for me to install sitting in the corner. Things have changed a bit since I learned to stick weld almost 50 years ago. At least I'll have converted an old bed frame into a welding cart for the wire feed welder if the bow does not require any work.
The used front bow I picked up was so bad that one side disintegrated the moment I started removing the remnants of the old top that was still on it and I hope mine is nowhere close to being in that condition. I was hoping to rebuild the used bow so I would not be several days without a top on the car while repairing the one currently on the car.
Why have it installed? It really isn't that tough, trust me! I didn't even have the advantage of taking off the old one to see how it fit on and everything, the car came to me sans top. I did it in an afternoon and it came out pretty near perfect. It was significantly simpler than I expected. It's pretty tough to screw up, because the front of the top is sewn so it fits on the front bow a certain way, and then the rear is sewn so it fits on that metal frame a certain way. The rest just drapes in between.
The only reason I'd pay someone else is if there was a lot of prep work to do on the frame, but you are talking about doing that yourself. The install is the easy part. I really don't know where they get off charging so many hours because I bet if I had to do it again now I could finish in 2-3 hours tops. Well...if the top has the strings sewn in to guide the wires.
Jay, if you can do your front suspension, you can Definitely do this . If by yourself, I would allow an afternoon. If you want to clean up the frame and paint, then allow the weekend. The top itself is no more than half a day. It is easier to get it on the front bow with two, considering the glue, but can be done solo. Just take your time. Also do it on a warm day so it stretches nicely.
sooooo it's pretty much a no brainer at this point took Fiona in to get my quote and it was an experience I'll summarize by saying first he asked to see the new top, then insults it 2) then he gave me this story about brands/manufactures of tops etc. 3) then he brought out this book and according to the year and car it takes 5 hrs @$75/hr for professional installation 4) I am not allowed to do any prep and the kicker 5) if they run into any issues they still complete the install and just add to the total regardless if want to proceed or not
so yeah I'm going to try my best and see what happens
Got my EasyUp out of the closet, stopped by Joannes Fabric and found some thin vinyl to cover the front bow at half price and had a 25% off coupon on top of that and got some rust restoration primer too. I picked up a full yard of the vinyl so I will have the option of covering the front visors to match.
The used bow I got had some foam rubber padding on it which appeared to have contributed to the rust issues. Is there supposed to be 3/16" closed cell foam rubber glued to the top of the front bow?
I looked at a pdf of the body section of the manual however it was scanned in black and white so the pictures are just black blobs on the page and not of any use. Does anyone have a link to clear pictures of the cable attachment points and rear anchors. The top on mine was just slapped on without any rivets or cables and some parts appear to be missing too. The old top still contains the strings to pull the cables through. I am hoping that the rear anchors were not discarded.
If you remove the front bow to clean it up how bad is realigning it?
Some say the use of glue on the front bow is optional. Any experience going without glue on the front bow?
I purchased my CS1 top from The Convertible Top Guys as a kit with the instructions, plastic removal tool, glue and verbal instructions but they sent me a CS2 top by mistake however a quick email and they have cross shipped a CS1 top and will be sending a prepaid label for returning the CS2.
Interesting thread. Makes me realize how lucky I was here in WI.
The shop which reupholstered my seats, Vic's Upholstery in Madison, also does convertible tops. I asked Vic how much he'd charge for a new top and installation. He told me to go out on the internet and purchase "the best top you can find", 'cause it would be less expensive than purchasing a basic vinyl top from him. He'd then install it for $250 labor and materials, and it would take two days. Bought a Haartz canvas top from convertibletopguys, and had Vic install it last summer. I couldn't be happier. He also made up a new vinyl boot, matching the interior, for $150.
If you're anywhere near Madison, at least give Vic's a call.
I can't believe $75/hour plus all the snark they can dish. Let us know how the top turns out, Jay.
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
