I now have direct-replacement aluminum radiators for 1800 and 2L Spiders. These bolt right in place of the stock radiator, use the stock cooling fan and fan switch. These radiators only weigh 7lbs!! $189 plus shipping
Nanonevol wrote:What does the stock radiator weigh?
I think aluminum is around 1/3 the weight of copper, but I saw online somewhere that an aluminum rad will be about 30% to 40% lighter. There must be more metal in an aluminum rad.
Thickness too? With the diesel conversion I have less than 1/2 inch between the oem radiator and the water pump shaft and I know that eventually I am going to need to replace the radiator.
Will it help the stock motors run cooler during hot weather using the stock fan? If so, how much?
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
