driveshaft center support assy and bearing.
- Your car is a: 1979 Fiat spider 124
on my 79 fiat 124, the driveshaft center link support assy is shot. The rubber is cracked, and falling apart. I am going to have to order a new/replacement one> Do I have to replace the bearing also? Is there some way to check the bearing?
79 124 spider
08 Silverado
09 HHR
08 Silverado
09 HHR
- azruss
Re: driveshaft center support assy and bearing.
that is a sealed bearing and the seal is probably shot as well. To inspect it requires pulling the drive shaft so you can spin it and see how it feels and inspect the seals.
It would be foolish to not replace the bearing as well, likely it's 20-30 year old just like the support.
Pro-Tip.
When you take the driveshaft apart, MARK IT to note which way its put together so you can put in put back the same way. You need to mark it in three places - Both U-Joints and the center spline needs to be marked. Ask me how I learned this.
Its best to go ahead and get a driveshaft rebuild kit. - all the vendors sell them for a reasonable price. The U-Joints come new with grease fittings, and they only like to go on a certain way, so be careful that they don't interfere with the rotation of the shaft when you install them.
yes, Tony< I have marked/notched the shafts and all other components, Thanks for the advise. (I used to own a Corvair)
I am going to order the new center bearing and support assy. And I am going to replace the U-joints also.
Thanks to all who replied. Your "know how" will come in handy.
79 124 spider
08 Silverado
09 HHR
08 Silverado
09 HHR
- Your car is a: 1980 Spider
Hi,kevireno wrote:yes, Tony< I have marked/notched the shafts and all other components, Thanks for the advise. (I used to own a Corvair)
Do you mind posting a picture of the parts you're replacing? I believe I too am in need of replacing mine, but don't have a service catalogue handy to look me up.
Thanks and good luck.
- johnsje6
Here is a link to the set sold by AR, should have everything you need.
http://www.autoricambi.us/product/DR5-4 ... --SAVE-20/
John J.
1979 Spider 2000
1979 Spider 2000
thank you all for the tech info. I have the bearing and the bearing carrier is on BO with vender. Yes, I did mark all shafts for assy.
I got an early Birthday gift. 12 ton HFT shop press. So, I am now working on the U-joints R&R. Any tricks/tips for U-joints.
79 124 spider
08 Silverado
09 HHR
08 Silverado
09 HHR
Proper alignment is the key to successful U-joint replacement. No amount of force will substitute. After removal, check for rust in the "bores", and treat with a brake hone if necessary. The job can be ten minutes or all day if you can't get things lined up.
Not on backorder form us:
http://www.autoricambi.us/product/DR5-4 ... t--1969on/
Been away from the project for awhile. In the meantime it got pretty cold so I decided to tackle the driveshaft inside where it's warm. I pulled off the old u-joints and then the support assy w/ bearing, but now putting on the new Support I can't seem to get the castle nut on far enough without causing the Support to bind. If I crank the nut down all the way, the bearing won't turn at all. Any idea what I might be doing wrong? The original support assy had a separate bearing that was held in with a circlip but the new one has ridges that hold the bearing in. I found a diagram showing the 2 cup washers and I think I have them in correctly.
See how the castle nut is not all the way in:
https://drive.google.com/file/d/1Z125Jk ... sp=sharing, https://drive.google.com/file/d/1jJ_s35 ... sp=sharing
Thanks, Rich.
Thanks, Rich.
72 124 spi bought new - the carcass is buried in the backyard
71 spi swapped drivetrain from 72 - sold in 88
71 coupe - traded for new Lancia
77 Lancia Beta Saloon
71 1608 spider - impulse buy - project
Thanks, Rich.
Thanks, Rich.
- Patron 2021
I took mine to a driveshaft shop. 80.00 i gave him the parts.
+1
Take it to a machine shop.
