Gauges
- Ptoneill
Gauges
Ok, so putting the chrome rings on my gauges turned into an exercise in frustration. I was thinking of going with aftermarket gauges... I found 4 inch speedo/ tach in VDO but I was wondering if someone has aftermarket gauges and could give me advice. I have a 79 carb and I would like to keep it fairly simple...ok as simple as the electronics on an Italian car can be.
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
- toplessexpat
Re: Gauges
I've used VDO gauges (voltmeter, EGT, external temp, clock) and done a custom face that sticks over the stock one. Looks ok. Couple of techniques to make it look right at night - either "stack" stickers or carefully align with the stock pattern so the through illumination looks good.Ptoneill wrote:Ok, so putting the chrome rings on my gauges turned into an exercise in frustration. I was thinking of going with aftermarket gauges... I found 4 inch speedo/ tach in VDO but I was wondering if someone has aftermarket gauges and could give me advice. I have a 79 carb and I would like to keep it fairly simple...ok as simple as the electronics on an Italian car can be.
Here's some I did...
Next ones I'll white out the needle too.
Andy
- btoran
- Your car is a: 1975 Fiat 124 Sport Spider
Re: Gauges
swapping to the chrome bezels is a pain, but can be done (and they look great when finished).
http://www.fiatspider.com/f08/viewtopic ... me#p200308
1975 Fiat 124 Spider
- v6spider
Re: Gauges
Autometer gauges are fantastic I'm using a full complement of them in my spider. And they are accurate and come in many styles. Full mechanical or electrical.
http://www.v6spider.com
Re: Gauges
V6spider, Awesome cluster. What is the gauge betwen the Air/Fuel and the clock? is that an amp meter? Well done.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- Ptoneill
Re: Gauges
btoran wrote:swapping to the chrome bezels is a pain, but can be done (and they look great when finished)
I read that link and it was usefull....I broke one lens, and the large bezels will no even fit over the 4 inch speedometer gauge..??
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
- Ptoneill
Re: Gauges
v6spider wrote:Autometer gauges are fantastic I'm using a full complement of them in my spider. And they are accurate and come in many styles.
I have looked at them, I wish they had 4 in gauges with chrome bezels...... I would like to keep the mechanical speedo as I have had nothing but grief finding a 5/8 inch digital output for the French made GM auto transmission I have.
Does look nice!
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
- v6spider
Re: Gauges
TX82FIAT wrote:V6spider, Awesome cluster. What is the gauge betwen the Air/Fuel and the clock? is that an amp meter? Well done.
Yes Clark is correct about it being a vacuum gauge. Btw I won't use an ammeter as the electrical system has to pass through it. Voltmeter is much better and still does the job for showing a discharge situation.
Actually, autometer does make gauges with a chrome bezel and I believe they would have the proper mechanical speedo for your tranny..Ptoneill wrote: I have looked at them, I wish they had 4 in gauges with chrome bezels...... I would like to keep the mechanical speedo as I have had nothing but grief finding a 5/8 inch digital output for the French made GM auto transmission I have.
Does look nice!
Cheers!
Rob
- v6spider
Re: Gauges
Check this out Pat..
http://www.autometer.com/cat_gaugeop.as ... or_tab-tab
http://www.autometer.com/cat_gaugedetai ... or_tab-tab
Rob
Rob
- Your car is a: 1972 124 Sport Spider
Re: Gauges
Buy the Stainless Bezels from AR. They basically press fit on over the gage and you wont need to bend the edge over to create a lip. Just run a bead of silicon around the inside of the bezel after you have seated the gage. I had to slightly sand the edges of the speedo and tach to get them to fit into the bezel.
All in all, very painless and you dont have to worry about damaging or denting them as much as you do with the chrome bezels.
Re: Gauges
toplessexpat wrote:I've used VDO gauges (voltmeter, EGT, external temp, clock) and done a custom face that sticks over the stock one. Looks ok. Couple of techniques to make it look right at night - either "stack" stickers or carefully align with the stock pattern so the through illumination looks good.Ptoneill wrote:Ok, so putting the chrome rings on my gauges turned into an exercise in frustration. I was thinking of going with aftermarket gauges... I found 4 inch speedo/ tach in VDO but I was wondering if someone has aftermarket gauges and could give me advice. I have a 79 carb and I would like to keep it fairly simple...ok as simple as the electronics on an Italian car can be.
Andy
Great idea man. Awesome DIY solution.
