I just need a new pressure plate for the clutch and some lower control arm bushings.
A 300+ hp naturally aspirated 4.3L Chevy vortec!WYSpider wrote:What v6 are you dropping in?
That is the plan actually.azruss wrote:all these big motor conversions make me nervous because you cut away the upper transverse bracing on the firewall. It seems to me it would be worthwhile to install a removable brace across that gap. It would help if your motor is aluminum.
