I am looking at putting an electronic speed sensor on my 79 with the TH180 automatic transmission. I am not familiar with this process although I did see several different ways to accomplish this. One is an adaptor to the outpost using the port the speedo cable leaves the transmission, can I still use the cable for the speedo? The second is a magnet assembly that goes around the drive shaft.
The drve shaft one looks simple, however it is diameter specific...does anyone know the exact diameter of the 124's driveshaft?
Electronic speed sensor
- Ptoneill
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
Re: Electronic speed sensor
I just measured the short shaft, between guibo and bearing, at 70mm (2.75")
- Ptoneill
Thank you very much....my caliper got stepped on!
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
I have one electronic speedo and i use the port of the speedo gear and made an adapter to fit the electronic sensor for Ford. Actually i made 2...
