I'm in the process of trying to set my timing on my '81 FI car. It runs well after timing belt replacement (even when accelerating and going at 60mph+) but want to get timing correct. So I was looking on the crankshaft pulley and it looks like there is a notch on the inner part (near the engine) of the pulley that doesn't line up with the notch of the outer part of the pulley (near the rad).
Here's a few pics...
The general area... you can see the white mark just above the indicator bracket
A closer view... notch seen through the hole and the white paint on outer notch.
So I'm thinking I'll use the inner notch and set the timing using the hole in the indicator bracket. I can't even see the indicator bracket anways because of all the rad pipes, etc...
