Where Coolant Hose Meets Cylinder Head
joelittel
Post by joelittel »
Can this metal hose insert piece be replaced? If so does anyone know what it's called and who sells them?
vandor
Re: Where Coolant Hose Meets Cylinder Head
Post by vandor »
I've never seen them new and have not known anybody able to remove one.
If you had a replacement I suppose you could drill it out or have a machine shop do it.
joelittel
Post by joelittel »
Ok thanks.
131
Post by 131 »
Mick.
joelittel
Post by joelittel »
That's a site I had not come across yet. Thank you.
weekend warrior
Post by weekend warrior »
I've done a few of these in stainless as in Micks previous post, can ship statewide. Would post an image but it was easier and quicker to machine stainless !!
divace73
Post by divace73 »
Here you go WW
That is a nice bit of gear
Cheers David
see my >>You tube channel<<
joelittel
Post by joelittel »
Weekend warrior what do you charge?
weekend warrior
Thanks Dave :D
Machined these from 316 marine grade stainless 7/8" hex bar ( so you can easily install/remove )
$60 aus or $55 us + shipping
bradartigue
Post by bradartigue »
Can you machine it to be about 4" taller so you can use a more common, molded U hose?
weekend warrior
bradartigue wrote:Can you machine it to be about 4" taller so you can use a more common, molded U hose?
I could but the extra cost would probably outweigh the difference between the rubber hoses
bdinardo
Your car is a: 1979 Fiat 2000
Post by bdinardo »
Hoping to revive this thread as that metal pipe is a bit more corroded on my 1979 than I would like. I'd like to replace it but the links in the thread above don't work any more. Has anyone been able to find a place to buy a replacement pipe? Thank you!
Spider951
Post by Spider951 »
I see that you have received no answers. I don't have one either, but I can tell you from my efforts to remove/replace that little piece of pipe that it is really, really in there. IIRC it is steel threaded into aluminum (so probably a galvanic action thing going on). I have tried on two different cylinder heads with no success - on one I applied so much torque using a pipe wrench (plumbers type) and "cheater" bar (about 4 ft of pipe on end of pipe wrench) that I feared I would shear the thing off (wouldn't budge - I only succeeded in deforming it). I also wondered whether it is reverse threaded but doesn't appear to be. Maybe some application of heat, or drilling it out, or welding a piece over it or inside might work, but I decided to give it up for the time being and just tried to remove as much corrosion as possible for now.
As least for the earlier spiders, the part number of this fitting is 4151673. I'm not aware of anyone that sells them, so you'd either have to find a good used one, have a machine shop make one, or maybe you can search online for "metric taper pipe fitting" and find something that would work. A metric taper hose barb of the right size would probably work.
To remove the fitting, heat is probably the answer. Like from a propane torch to get it pretty hot. Let if cool down, and remove with a pipe wrench. I'm thinking it would be much easier if the cylinder head were removed and on a workbench.
To be honest, unless this pipe is so corroded that you can't get a leak-free connection, I'd just leave it alone. It's just one of those unfortunate fixes that sometimes takes more effort than it's worth.
Spider951
Post by Spider951 »
Aluminum, steel, and water (and time) all in contact with each other is a recipe for a galvanic cell, hence corrosion between two dissimilar metals and the possibility of a type of "welding". Whew.... that's all I remember from college chemistry (even with Father Guido Sarducci's 5-minute university refresher course [Saturday Night Live, early 1980's(?), for you young folks]). I would urge caution with whatever you do (I could have had a Homer Simpson "Doh" moment had I continued with my strong-arm tactic with my big cheater bar for more torque). That aluminum cylinder head is a lot more expensive than a 3-4 inch piece of steel. I don't think the corrosion can be undone? (any chemists out there?). In one of my former lives my oil-field roughneck friends would have said "use a bigger hammer", but they dealt with strong thick metals (serious steel). I would like to know what experience teaches us on removing this little threaded steel tube troublemaker. Surely someone has tackled this..??
