I've been looking at these cams from Colombo & Bariani. Has anyone had experience with this brand?
Here are the specs.
Application Road medium
Cam lift IN 10.3
Cam lift EX 10.3
Duration 280°/272°
Timing 28°-72° / 66°-26°
Lobe center angles 112°/110°
Valve lift TDC 1.9 / 1.8
Clearance 0.40 / 0.45
I'm looking to build a 2 litre engine with a Regata 100s big valve head. I need advice on the best pistons as well as any thoughts on these cams or any other brands you'd recommend.
Angelo
Colombo & Bariani cams
- Your car is a: 131 supermirafiori
Re: Colombo & Bariani cams
Hi!
If I don't remember wrong,aren't they the one who makes all the OE cams to Fiat/Lancia.
Also think they made the cams for Alquati,...
Cheers Alf
Cheers Alf
