Understanding High Compression Pistons for 1608
- smbaird37
- Your car is a: 1971 Spider
I am looking for a set of HC pistons for my 72 spider. I have found a few possibilities that say the pistons are high compression but give no specifics. HC pistons for the 1800 and 2L engines give a dome height in mm. What should I be looking for in 1608 pistons? Any info greatly appreciated as always...
~Steven
~Steven
1971 124 Spider
1973 VW Adventure Camper
Re: Understanding High Compression Pistons for 1608
Good question, I can get a answer toosmbaird37 wrote:I am looking for a set of HC pistons for my 72 spider. I have found a few possibilities that say the pistons are high compression but give no specifics. HC pistons for the 1800 and 2L engines give a dome height in mm. What should I be looking for in 1608 pistons? Any info greatly appreciated as always...
~Steven
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1975 Spider
i have a set of 9.8-1 pistons for a 1608 in my shop, at least 3 of them, ill check the dome height tomorrow and post
son has 78 spider
son has 78 spider
What are the ones I bought..60mmBEEK wrote:i have a set of 9.8-1 pistons for a 1608 in my shop, at least 3 of them, ill check the dome height tomorrow and post
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- smbaird37
I think you might be mixing the overbore dimension with the dome height? The stock bore is 80mm - then the plus sizes .4, .6, .8, and 1. You bought the 80.6mm overbore pistons right? If I got my geometry right, this gives you slightly greater displacement but actually lower compression since you increase the size of the combustion chamber. Unless of course, the pistons have a high dome (i.e., high compression). I look forward to learning what Beek finds out....fiat218 wrote:What are the ones I bought..60mmBEEK wrote:i have a set of 9.8-1 pistons for a 1608 in my shop, at least 3 of them, ill check the dome height tomorrow and post
~S
1971 124 Spider
all 1608 pistons i've seen so far have same height dome
I bought a over size0.60mm
I was wondering if they would be ok,with the cam set up of 42/82. If not then I'd getting better pistons
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- smbaird37
Chris Obert has a set of 80 + .6 Mondial pistons for sale. He states that the dome is approximately 4.75 mm.
1971 124 Spider
- FiatMac
Boring oversize and installing oversize pistons increases the displacement (swept volume) and leads to a slight increase in compression. The compressed volume is only minimally affected by the increase in bore. Compressed volume is the sum of the head combustion chamber volume, deck clearance volume(can be a positive or negative value base on whether the piston is below or above the deck at top dead center), piston land clearance volume, head gasket clearance volume, and piston dome volume(negative value). The only two affected by the bore diameter are the deck clearance and the piston land clearance volume, both of which are very small compared to the increase in swept volume.smbaird37 wrote:....... If I got my geometry right, this gives you slightly greater displacement but actually lower compression since you increase the size of the combustion chamber.
~S
Compression Ratio = (Swept volume + Compressed Volume)/Compressed Volume
In a stock 1608 engine going from stand bore to 0.6mm over would increase compression by about 0.1 units.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
78 124 Spider on the rotisserie
76 124 Spider parts car or possible Lemons racer
83 parts car
83 parts car
- smbaird37
Thanks Stan! Great explanation! After I posted I began to think that I had not thought it out all the way..FiatMac wrote:Boring oversize and installing oversize pistons increases the displacement (swept volume) and leads to a slight increase in compression. The compressed volume is only minimally affected by the increase in bore. Compressed volume is the sum of the head combustion chamber volume, deck clearance volume(can be a positive or negative value base on whether the piston is below or above the deck at top dead center), piston land clearance volume, head gasket clearance volume, and piston dome volume(negative value). The only two affected by the bore diameter are the deck clearance and the piston land clearance volume, both of which are very small compared to the increase in swept volume.smbaird37 wrote:....... If I got my geometry right, this gives you slightly greater displacement but actually lower compression since you increase the size of the combustion chamber.
~S
The pistons from my donor engine are stamped RA2661 0.60 and TOP 0.04 UL. So also +.60 - anyone know what the second stamping means? Also, I measure the "dome" on those to be 3mm. Probably stock.
1971 124 Spider
the 1608 pistons are in my storage area, they are a higher dome than the us spec 1608. i just have to find them
son has 78 spider
son has 78 spider
- smbaird37
OK found good info on Mirafiori and will paste here for everyone:
(1608 pistons) Are shorter in Length, a lot, than 1438cc Pistons.
When working with PBS Back in the Day, they "could" adapt/convert 1438cc
Pistons and make them workable for 1608cc Engines... with a Lot of Cost.
And... Vice Versa.
Yet, PBS advised against "Converting" 1438cc to 1608cc Pistons...
saying it was "pointless" and better to pay through the Nose to get Correct
Pistons... so, Imported all USA versions of 1438, 1608 (and 1592) Borgo Pistons
1608cc AE Borgo, SpA Pistons
*not mentioning AE, generic, cataloguing - it's consistently self-contradicting
Borgo# 66.6705 1608cc 125BC.040 (C/R 8.5:1)
124 Sport USA Spider Coupe
3mm Compression Height, 69.25 Total Piston Length
Borgo# 66.6523 1608cc (Coupe 125BC, Spider 125BS) ... C/R 9.9:1 (drool)
Works on USA 1608cc DOHC's with Clearance
4.8 Compression Height, 74.3 Total Piston Length
*** NOTE for SPOTTERS of DOHC 1438 or 1608 NOS OE Borgo Pistons ***
Repco, USA, Imported AE Borgo in the DOHC 1438 + 1608 with a "Private" Mark.
(AE Borgo in the Repco Box, white with Repco Label or Repco Corporate Colors)
Repco "Private" Production Pistons will O.N.L.Y be Stock Compression...
Marked as Follows...
1438cc ... RA 2664 (Borgo# 66.5946 Not on Piston or Boxing)
1608cc ... RA 2661 (Borgo# 66.6705 Not on Piston or Boxing)
And... Vice Versa.
1971 124 Spider
- Your car is a: 1970 128
Most of these options i'm sure are long gone by now, finding pistons is possible but having choices on brands
compression ratios will be very limited unless you go custom made. If you search the web you may find just
what your looking for as i did a few years ago for a 1608 build. I found an old New Stock set for sale online
someone must of been sitting on these for a long time then decided to sale them off.
Daniel is still around ?Daniel wrote:Most of these options i'm sure are long gone by now, finding pistons is possible but having choices on brands
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
