Big Brake Kit-first pics
We've completed the fabrication to retrofit the front brakes from the new Fiat 500 onto the Spiders. This upgrades the brakes from the original 9" solid rotor to a 10.25" vented rotor and also uses the 500 caliper. Here are the first pics
URL=http://smg.photobucket.com/user/socalma ... 0.jpg.html]Image[/URL]
Tobi
Re: Big Brake Kit-first pics
Post by Tobi »
Does it move the hub further out and how big in diameter do the wheels have to be?
the hub is still in the original postion as are all other steering and suspension pieces. It's a pretty easy upgrade.
The system won't fit 13" wheels. 15"s fit without any issues and we'll by trying 14"s in the next day or so
SLOSpider
Post by SLOSpider »
That is nice. Having the 500 come on shore seems to be helping us spider owners. WHo would have thought they would have kept the bolt pattern the same :)
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
divace73
Post by divace73 »
looks great Mark, is it okay to use the same master cylinder?
And also what cost are we talking about?
Cheers David
see my >>You tube channel<<
the same master cylinder works fine. Kits will come in various levels. I'm trying to source calipers from 500 owners that upgrade their stock brakes to keep costs low. So we'll be selling kits like this;
starter kit; includes brackets and braided hoses. Owner provides their own calipers, pads and rotors
basic kit; includes brackets, hoses, stock rotors, pads, calipers
perf kit; includes brackets, hoses, EBC slotted rotors, EBC perf pads, calipers
Sorry but pricing isn't completed yet
azruss
Post by azruss »
Mark, do you have any idea how much unsprung weight is added.
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
Fingers crossed that14" turbos will fit.
Trey
ga.spyder
Post by ga.spyder »
Great idea.That is an upgrade I will be very interested in.
Craig Nelson
Fling It Around Turns !
I haven't compared weights between the two sets of components, but I will be doing that. Obviously the rotor will be heavier and the adapter bracket is a little heavier than the oem caliper mount but I feel the trade-off in improved braking will be worth it.
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Post by v6spider »
Very nice indeed! I'm guessing there's possibly more choices in aftermarket wheels in that bolt pattern since the release of the 500 in the states...
Rob
http://www.v6spider.com
manoa matt
Post by manoa matt »
You can loose almost 1/2 pound of unsprung rotational weight if you ditch the stock steel wheel spacer and use an alloy one. There is a common aftermarket universal one that is the right thickness and extremely light.
good news! the 14" alloy wheels fit the big brakes!
Holshot
Your car is a: 1982 TURBO Spider 1979 Spider
Post by Holshot »
Hey Mark,
Looks great! Way to bring the Spider into the 21st. century with more modern braking... One question, aside from the mounting and proving that they fit can you give us som feed back of how they perform? Brake pedal feel, stopping distance compared to a well working stock original setup, vibrations, pulsating ect... I know you said the stock master will work with this setup but i know in some cases with other platforms by increasing to larger diameter brake discs and calipers didn't really do much or give the results expected do to other areas that were not addressed like master cylinders, proportioning valves ect... Thanks for the pics and all the R&D looks very promising!
Regards,
Giuseppe
Giuseppe
1979 Fiat Spider
1982 Fiat Spider TURBO
1984 Pinninfarina Spider (gone but not forgotten)
I haven't finished all of the other work on this car yet, so it's been short test runs on our street. There are no vibrations or pulsations, the brackets are steel and very strong, so no flexing at all. In fact, the caliper mounting brackets are much sturdier than the brackets the Spider came with. Once we finish this car, I'll do some distance comparison, but I can tell already that the car stops much quicker
