Distributorless ignition help
- Kendoo
- Your car is a: Fiat 124 Spider 1976
I have just started to put in mark's distributorless ignition kit and am swapping it from the head to the block and am wondering how I get the drive gear off the old dizzy and onto the new kit, the shaft on the new kit seems very small in diameter compared to the old shaft, should the kit have come with a gear?
Matt
2014 GT-P FPV
1976 Spider 1800cc (current toy)
2011 Ford G6E Turbo
2002 Alfa Romeo 156 Selespeed (a few years back)
Datsun 1600 Rally Car (Those were the days)
2014 GT-P FPV
2011 Ford G6E Turbo
- azruss
Re: Distributorless ignition help
the drive thru the bottom hole is completely different that the drive on top. as i recall the early dizzies had a straight spline thats like 3/8" diameter.
- Kendoo
The new unit has a spline which I imagine is to take the drive gear, but the old dizzy has a straight shaft around 1/2". The new unit has a straight shaft with a spline around 3/8". Always good to find this **** out when you have stripped it all down, was hoping to take it for a drive today.
Has anyone done this conversion on a 1800 motor?
Matt
2014 GT-P FPV
2011 Ford G6E Turbo
2014 GT-P FPV
2011 Ford G6E Turbo
- Kendoo
My god, what a halfwit I am. Took the block plug out and there is a beautiful little spline hole in there ready to go. Hope this helps someone else though, that is someone as stupid as I am.
Matt
2014 GT-P FPV
2011 Ford G6E Turbo
2014 GT-P FPV
2011 Ford G6E Turbo
- Kendoo
Well I finally got it done and it is running sweet. Seems to have more mid range torque.
Only a couple of dramas, as it is a right hand drive had to remount the coolant reservoir to get it out of the way of the coil and the fork which holds down the dizzy had a different stud hole size from the head to the block and the block fork did not fit the new unit properly. Swapped them over and drilled out the hole (boy those forks are made out of very hard steel).
Apart from all that it went in and tuned real easy.
Matt
2014 GT-P FPV
2011 Ford G6E Turbo
2014 GT-P FPV
2011 Ford G6E Turbo
we don't normally swap the hold downs. On the block side, the inside edges of the fork need a small amount of grinding to fit the trigger unit
Mark is a rev limiter required ?So Cal Mark wrote:we don't normally swap the hold downs. On the block side, the inside edges of the fork need a small amount of grinding to fit the trigger unit
- Kendoo
Rodman,
These units will produce an excellent spark right up to 12,000 rpm. The only rev limiter I have is when I feel the power dropping off, what is that red mark on the tachometer for anyway?
Matt
2014 GT-P FPV
2011 Ford G6E Turbo
2014 GT-P FPV
2011 Ford G6E Turbo
lmao thanks for the your input.Kendoo wrote:Rodman,
I have it in my 79
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
