cam
fiat218
cam
Post by fiat218 »
if i was to add a mild cam to a stock 2.0. would i feel the differnce in power/speed. everything eles should work fine rite
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
narfire
Re: cam
Post by narfire »
Yeup, you might notice the difference. To make it all worth while though, I'd recomend the adjustable cam wheels to get the most/best out of that cam. You will definately notice the difference then.
Re: cam
mild cam is the key phrase with a stock 2L, they don't have enough compression in stock form to use an agressive cam. You will notice a difference in the midrange with the right cam
fiat218
Re: cam
Post by fiat218 »
So Cal Mark wrote:mild cam is the key phrase with a stock 2L, they don't have enough compression in stock form to use an agressive cam. You will notice a difference in the midrange with the right cam
and then use the adjustable cam wheels like narfire mention?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Daniel
Re: cam
Post by Daniel »
or you could re index your cam pulleys
fiat218
Re: cam
Post by fiat218 »
Daniel wrote:or you could re index your cam pulleys
what does this mean , re index?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Daniel
Re: cam
Post by Daniel »
the hole for the pin that keeps the cam from spinning on the pulley, if you drill a hole in another area with the
right location you can change the timing that way without adjustable timing gears.
fiat218
Re: cam
Post by fiat218 »
Daniel wrote:the hole for the pin that keeps the cam from spinning on the pulley, if you drill a hole in another area with the
I have no idea how to do that stuf but thanks,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
