Hi,
Good ripping day yesterday in S NY, SW CT, dialing in the DFEV from gas station to gas station...
Hitting about 70-90, just to keep up, resulted in something that's best described as an aerodynamic oscillation; felt in the wheel as well but not a shimmy... Fluttering spoiler perhaps?
How to determine, how to cure?
Mark
Spoiler Flutter?
- opus10583
- Your car is a: 1978 CS1
Spoiler Flutter?
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
- Your car is a: SOLD
Re: Spoiler Flutter?
Do you still have the splash pan installed that covers the area in front and sides of the oil pan? (lots of folks remove these splash pans) If so, is it properly fastened? If you have it installed and it's loose it could be acting like an air brake underneath your car at speed.
Just a thought.
Just a thought.
SunnySideUp
Mark, when you say not a shimmy? I'm not 100% sure that it is not something coming from the wheels. I'm sure you already checked your air dam/spoiler at the front of the car to ensure it is not loose in any way. I had a Yugo in the 80's that shook like hell once over 60 miles per hour because the alignment of the car was off. With that said, I would not overlook the tire pressure and review the wear patterns on the tires. I've seen where tires out of balance will shake the car at higher speeds.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- opus10583
Hi,
Thanks.
No pan. ...Though I may refit it to localize the oil drips.
Spoiler is secure, alignment was recently (mileage) set - have the cocked wheel to prove it...
Tires are 5yr old but new 175/70-13 P3000, 34psi front 32 psi rear @ ~60deg F.
I replaced the front (and rear) suspension last summer, all but right side tie rod ends.
No problems with noises, vibrations, pulling, etc. until certain speeds are reached.
Mark
Thanks.
Mark
Interesting problem! When you replaced your suspension, did that include replacing the shock absorbers? Maybe one of the shocks is beginning to fail. Front shock towers in good condition?
How's the rubber donut on the drive line? Any splits or cracks? Chunks missing? Center carrier bearing in good shape? I ask as maybe the resonance of something being slightly off or worn is traveling and is showing up in the steering wheel.
Has your car ever been in an accident?
SunnySideUp
- opus10583
Hi,SunnySideUp wrote:Interesting problem! When you replaced your suspension, did that include replacing the shock absorbers? Maybe one of the shocks is beginning to fail. Front shock towers in good condition?
4 new KYB shocks as well. Shock tower repair was an unpleasant requirement last summer as well. Guiboo and bearing are fine.
I'll have the wheels rebalanced again, but it just doesn't feel like that.
Mark
- 124JOE
get a big fan
set in place
observe car
hope this helps
get a big fan
set in place
observe car
hope this helps
What about wheel bearings? Maybe a loose hub? Engine mounts?
I suppose the process of elimination is next. Remove the front spoiler, and give it a try and see if you still have the "oscillation" issue. If that doesn't cure it, then maybe triple-checking everything that was done over the last year and make sure all things are snug/tight-to-spec.
SunnySideUp
- opus10583
Hi,
Wheels being balanced, again; front end being aligned*, again; tomorrow. Cross-member fasteners being checked as well.
*I've asked them to dial in 45' of negative camber: Understeer makes me sad.
Ciao,
Mark
Ciao,
Mark
My car had a bit of vibration/mild shake (at lower speeds than you are discussing, maybe 40-50mph), and it went away after I properly torqued the engine mounts, 3 of which were loose.
- opus10583
Noted, thanks!RRoller123 wrote:My car had a bit of vibration/mild shake (at lower speeds than you are discussing, maybe 40-50mph), and it went away after I properly torqued the engine mounts, 3 of which were loose.
Mark
