ADF 34 install and plan
Turbofiat124
Your car is a: 1980 Spider 2000 turbo
Re: ADF 34 install and plan
Post by Turbofiat124 »
beachspider wrote:Well I got a new 34 ADF in the mail today. Two problems. One of the connections for the water choke was completely broken off. Does the unit from the stock carb interchange with this? Two, no distributor vacuum advance connection this carb. What do people usually do about this? I see some have drilled one in but I've never done something like this. What's the best course of action? Do most people tap a connection into the base of the carb or do they go with ignition/distributor change that would do away with the need for the vacuum line?
Just hook the vacuum advance directly to the intake manifold. It will idle much better. Of course you will have to unplug it and plug the hose off when setting your static timing.
The only difference as far as ported vacuum (before the carb, air cleaner) and manifold vacuum (intake manifold) is with ported vacuum, the vacuum advance won't engage until you crack open the throttle. This was the way vacuum advances were intended before EPA mandated that the vacuum signal must be taken before the throttle plate. Apparantly too much advance at idle raises emmisions or something. According to the folks who set the rules who probably take mass transit back and dourth to work and don't even have a driver's licence.
geno58
Post by geno58 »
Watch E-bay for the intake as well as this fourm, I just bought one from a guy in Pa. for $50.00 plus $16.00 for shipping.
Be patient and watch E-bay, I watched for 2 or 3 weeks, one poped up, made an offer and was very happy with the part.
In the process of installing it right now, so far so good.
