How much POR15?
How much POR15?
In the immediate future, we plan on removing all the floor insulation and putting down a layer or POR15 across the entire floor, followed of course by new insulation/sound deadening and a new carpet set. Anyhow, does anyone know what size can (pint, quart, or gallon) of POR15 we will need to purchase in order to coat the whole floor sufficiently? We are thinking the quart size, but we haven't been able to find a finite answer through the search feature, so we're are hoping someone can help us out. Thanks!
-Zulu
-Zulu
- red107
- Contact:
Re: How much POR15?
With POR-15 a little goes a long way. I used it last on my buddy Bug. We had a Qt and had some left over after doing the complete floor pan top and bottom, fender lining, inside the body and many other area. It goes on very thin almost like water. Very good product.
1981 Fiat Spider 2000
2018 Jeep Wrangler JLU
- kilrwail
Re: How much POR15?
We used a little more than one quart to cover both the top and bottom of an open 18' car hauler last year, so one should definitely be enough. Wear long sleevs and long pants that you don't care about, because you will get splattered and it doesn't wash out. If you get it on your skin, nothing takes it out except time - about 2 weeks!
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
Re: How much POR15?
How do you apply it? Is it thin enough to use the paint gun? I might be attempting a 72 later this year.
Zulu... I love your choice of cars
- kilrwail
Re: How much POR15?
You can use a 3-4" roller for speed (and splatter
) and a brush for the corners and tight spots. If you have a disposable spray gun and plan to do it in a deserted field, go ahead! LOLOL
Peter Brownhill
Peter Brownhill
Re: How much POR15?
I went to the this website: http://www.stoprust.net
Which POR15 product do you recommend for the floor pan of the spider?
Thanks.
Thanks.
Re: How much POR15?
Use the regular stuff.
If you're not familiar with the product, POR-15 uses the moisture in the ambient air to cure the paint. So it is imperative that you pour out of the can only what you can use within the next hour or so, and you can't dump the remainder back into the original can. Any POR-15 on the lid or in the groove of the can will seal the can permanently.
What I do is take a fresh pint of the stuff and portion it into a dozen baby food jars. An ounce or two will cover about one square foot; if I need more, I open another jar. Remnants in the jar get tossed. Also use disposable brushes, and be sure and cover any skin you don't want painted; the stuff is virtually non-removable.
Re: How much POR15?
Wow! Sound like the right stuff to seal the floorpan. Thanks for the tip on the baby jars. This is why I like this news group.
Re: How much POR15?
What kind of prep needs to be done to the metal you are about to treat? Does it need to be bare, clean metal? I have an enclosed trailer I need to treat. Do you paint over it or is it durable enough to withstand the elements?
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
- kilrwail
Re: How much POR15?
Treat it like you would for Tremclad. Wire brush the loose stuff, vacuum thoroughly and have at it. It doesn't need a top coat, but it wouldn't hurt to use a second coat and/or some other paint for an exposed trailer.
Peter Brownhill
Peter Brownhill
Re: How much POR15?
Requires a topcoat if the surface will be exposed to sunlight. The POR-15 website has complete info.mdrburchette wrote:W Do you paint over it or is it durable enough to withstand the elements?
I would recommend at least hot water and detergent or petroleum-based paint prep on sound surfaces. Any rusty metal should be treated with their acid solution beforehand.
- seabeelt
- Patron 2019
Re: How much POR15?
Not to keep harping on Eastwood, but they have a similar product that is supposed to be better than the POR-15. Check their website and do the POR 15 search they have posted the results of both products quite well.
Re: How much POR15?
This is the best anti-rust paint that I have found:
http://www.masterseriesct.com/
Trey
Re: How much POR15?
Awesome replies everyone, thank you. This knowledge will certainly help our process. Hopefully we will be actually doing this within the next two weeks or so. We will be sure to report back.
@narfire Thank you, I plan well ahead.
-Zulu
-Zulu
