Headgaskets
- henry
- Your car is a: Pininfarina 1983
Headgaskets
Are there such thing, as "Performance headgasket", thinner to improve compression?
Henry.
Henry.
Re: Headgaskets
Can't imagine that a head gasket could be thinned enough to still be reliable and make a real difference to compression. I think any "performance headgaskets" that you may see advertised refer to the durabilty of the gasket. may even be a little thicker.
Re: Headgaskets
there are multi-layer steel head gaskets that are thinner than the oem gasket. This would give a slight compression bump and this type of gasket is preferred for iron block aluminum head motors. The only problem is that they cost about $100 each
- henry
Re: Headgaskets
Better the 1800 head on a 2000 or the multi-layer headgasket?\So Cal Mark wrote:there are multi-layer steel head gaskets that are thinner than the oem gasket. This would give a slight compression bump and this type of gasket is preferred for iron block aluminum head motors. The only problem is that they cost about $100 each
Thank You.
Henry.
- manoa matt
Re: Headgaskets
Tako, Goetze, and Fel-Pro to name a few. I've heard good things about the Goetze and the Fel-Pro but have never used them. I actually may have a Goetze, but can't tell for sure as it only has a single letter "G" printed on it, no other marks anywhere else. I ordered a "performance" head gasket from Bayless a little while ago. It is about 2mm thick compared to the other gaskets I have that around 1.4mm-1.5mm thick. Also the Bayless gasket does not have the pre-formed silicone seal around it on either side.
I am going with a 1592cc head (same head cc as 1.
on a 2L block and wonder about the thicker gasket lowering the compression I'm trying to increase with the head/block combo. .5mm seams like enough to reduce the compression.
- henry
Re: Headgaskets
Thank you for the information, Where can I buy them? also, Where can I get a good 1600 head for my 2l?
Henry.
Henry.
- manoa matt
Re: Headgaskets
You can get Fel-Pro gaskets from Parts America or Autozone. Check their websites and enter your vehicle information. Of course the usual vendors have theirs, but they are usually Tako brand. Bayless sells their thick "performance" head gasket for $19.95. I have an extra head gasket, its not Tako, but I'm not sure what manufacturer it is.
The 1592 head is a rare head due to the limited production run, but it has the same head space as a 1.8 head so there is no compression increase, however the benefits are that it does not have the air injection ports which makes it a cleaner head, and the water jacket is bigger around #3 which equals more cooling, resulting in less head gasket failures that typically happen between cylinders 3 and 4. (or so I've read)
- henry
Re: Headgaskets
I couldn't found the gasket in this two websites, What's the thickness of the one you have?
- engineerted
Re: Headgaskets
Try Rockauto.com and get the fel-Pro gastket this one of the best.
Ted
Ted
Ted
- henry
Re: Headgaskets
Thank you Ted, They do have it but I don't think is the multi-layer steel one, that I'm looking for.
Henry.
Henry.
Re: Headgaskets
Wossner has what you're looking for. Here is the link. Scroll down to Lancia Delta Integrale 2.0. They make 3 different thicknesses.
http://www.woessner-kolben.de/english/indexenglish.html
They now have a warehouse in Los Angeles
- henry
Re: Headgaskets
I enter the website but they only produce pistons..... I mail them an e-mail asking for the gaskets.
Thank you,
Henry.
Thank you,
Henry.
Re: Headgaskets
isnt there an issue with water passage or something when using a 1608 head on a 2 liter? if not i have a 1608 head and a complete 1608 motor available. od, the 1592 head is similar to the 1800, i forgot. a
- Tappy
Re: Headgaskets
lol i did look hard took me 20 min anyway , 117,81€ is indeed pricey for a headgasket ,1.1 mm thick , would that increase compression you think ? Has anyone has experiences whith those ?So Cal Mark wrote:the link is there for gaskets, just look a little harder
