I am curious if anyone has installed a high perf. ign. module on their F.I. Spider? There is one listed in the Vicks catalog,for around $100.I wonder if the results are worth the money.I have installed these units in other makes with pretty good results,usually with a hotter coil.I am all for bolt on performance,especially on the F.I. cars where upgrades are limited.
Craig
High Performance ignition module
- ga.spyder
Craig Nelson
Fling It Around Turns !
Re: High Performance ignition module
I've used a couple of them, but not what Vicks' sells, and had good results. Along with an e-coil it creates a great spark with higher revs
I'd like to hear more details about this. I am a "keep it original" kind of guy, but a little more pep might help me keep up with Ace on the runs.
Ron
Ron
- manoa matt
Summit sells that Accel ignition module for around $40 Summit part # ACC-35361
I got a Accell coil & module off Ebay, paid $50-60 for both. I don't know if they helped performance, but they look better
The MSD one is supposed to be the best.
Trey
I'm running the MSD box with Blaster II coil on my 72 and the original 79 model setup with GM module on my 71. It's hard to determine which is best since my cars are completely different. I doubt paying more for a better ignition system would help my poor ole 71
but I had my 72 dynoed before and after the engine rebuild and swap to the MSD. At around 6200 rpms the chart showed irratic ignition issues before but was more consistant after.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
- ga.spyder
This is something I am going to look into,thanks for the feedback.Mark,what is a e-coil...brand name or a type of coil? I see several 'hotter' coils for fairly cheap,any reccomendations on type or brand? I will look into my Summit catalog,thanks for the part no., Matt.
Thanks, Craig
Thanks, Craig
Craig Nelson
I think the e-coil is a factory Ford coil, but for what I don't know. Here's the Mallory replacement: http://www.dragracingonline.com/itsnew/iv_8_1.html
Trey
- henry
- Your car is a: Pininfarina 1983
Can this module be install to a 1983 Pininfarina?
Thank you.
Thank you.
- ga.spyder
Henry, it can be installed in your car.I bought the module and an Accel coil from Summit Racing.Truthfully,I cant really tell much of a difference. After running the module for a few weeks ,it failed..quit..gone. Had a time figuring out what was wrong.I have the stock module back in,and I bought a spare for $20 at Autozone.
Craig
Craig
Craig Nelson
