Does anyone know if there are relays or particular sensors that could be the problem, or what I can check ?
Seems like the Radiator Fan should be coming on at some point triggered by a switch? relay? sensor? at about the temp that the gauge is shorting out.
I connected power and ground to the Radiator Fan and the Fan does work just fine, but I have never yet seen the Fan get switched on automatically.
I see there is a wired switch/sensor? at the bottom of the radiator and one at the fitting at the top in between water hoses in front of the timing belt cover, but not sure what they do, or if one of them could be the cause of the problem?
Thanx if anybody can help guide me to a solution. (electrical stuff is a real weak point in my bag of skills)
