Shifter
Anbele
Your car is a: 1979 Spider 2000 CS2
Shifter
Post by Anbele »
I’ve been trying to find out the answer for this by looking at many pictures—to no avail…the question is: how does the shifter boot fit over the shifter rod? I’ve seen many where the boot is covering the whole shifter—which I believe is wrong, since the shifter rode is beautifully chromed, I’d imagine to be seen. I’ve seen the ones where the boot looks like an upside down folded umbrella…so which is/was the “factory” setting?
ORFORD2004
Re: Shifter
Post by ORFORD2004 »
It depend if you have the short shifter
Anbele
Re: Shifter
Post by Anbele »
mmm…thought the short shifter was an aftermarket option?
Re: Shifter
I know that there are at least two different lengths for shifter levers, as my '69 and '71 are different (short and long, respectively). The '71 may be original, but I know the '69 is not because some doofus reached into my car and stole the original shifter when the car was parked (with the top down) outside a store. So I found another shifter. Sigh...
I have vague recollections of about 2 or 3 inches of chrome shifter rod showing above the boot in my original spiders, but this goes back 40 years and longer.
Redwolf
Your car is a: 1977 Fiat 124
Re: Shifter
Post by Redwolf »
18Fiatsandcounting wrote:I know that there are at least two different lengths for shifter levers, as my '69 and '71 are different (short and long, respectively). The '71 may be original, but I know the '69 is not because some doofus reached into my car and stole the original shifter when the car was parked (with the top down) outside a store. So I found another shifter. Sigh...
What a weird thing to steal.
TheBender
Patron 2019
Patron 2019
Your car is a: 1978 124 Spider
Re: Shifter
Post by TheBender »
This is how the PO had it set up on my 78. I’ve since changed it and not sure what the OEM set up was.
TheBender
Patron 2019
Patron 2019
Re: Shifter
Post by TheBender »
Here’s a dealership marketing brochure I have from 78. A little dark but it does look like a few inches of the shifter is visible above the boot.
