Power windows
BCK1
Your car is a: pininfarina spidereuropa 1983
Power windows
Post by BCK1 »
My 83 spider has a problem with one of my power windows The passenger side hoes up but not down I pulled the door panel off and all seems good. Am planning to switch the wires to the other side which works Ok. That way I can see if it is the switch. Question. How do you remove the switch without breaking it. Does is come out as a subunit? Any guidance would be appreciated. Thanks. Brian
Online
ORFORD2004
Re: Power windows
Post by ORFORD2004 »
I remove switch from both end to pull all the switches.
https://autoricambi.us/power-window-switch-1983-85/
BCK1
Re: Power windows
Post by BCK1 »
Thanks for your response. Do you mean to remove all the switches or just the power window unit like the one Auto Ricambi sells.
BCK1
Re: Power windows
Post by BCK1 »
So after carefully removing the panel I have tested the switch and both windows go up and down using the good side of the switch I just ordered a new one so should solve the problem. Thanks for the help Brian
BCK1
Re: Power windows
Post by BCK1 »
Update on my power windows . New switch received from Auto Ricambi and installed. Both windows up and down without problem but now having trouble inserting the panel back in the console. It’s a tight fit and has clips top and bottom which I assume hold it in place but hinders the panel insertion I am afraid of breaking the panel if I force it. Any hints or suggestions. Thanks Brian
Online
ORFORD2004
Re: Power windows
Install the panel empty.
BCK1
Re: Power windows
Post by BCK1 »
Thank you so much. All together and working perfectly. All the best. Brian
