Hello-
I spent a good time browsing the forms.. and can’t find a solution.
I am hooking up a subwoofer under the glove box of my 78 - 124. I need a good remote signal to turn on when the ignition is in the run position (+). Can someone help ID the wire from the ignition harness.
Thank you
Ignition - run position / remote
- Your car is a: 1978 Fiat Spider
78 Fiat 124
Re: Ignition - run position / remote
Possibly the pink wire or light blue / black... with a fuse oh course?
78 Fiat 124
Your head unit should have a remote turn on wire +
Sounds like fuse 9 or 10 is a good source too. 16 amps.
78 Fiat 124
I think only one of the fuses 9 or 10 should be 16 amps. which ever one has the horn on it. The other fuse should be 8 amps. Also I believe fuses 9 &10 do not go through the ignition switch they have power as long as the battery is connected in the car. I think switched power is on fuses 1 & 2.Sounds like fuse 9 or 10 is a good source too. 16 amps.
Oh I see! Got that mixed up.spider2081 wrote:I think only one of the fuses 9 or 10 should be 16 amps. which ever one has the horn on it. The other fuse should be 8 amps. Also I believe fuses 9 &10 do not go through the ignition switch they have power as long as the battery is connected in the car. I think switched power is on fuses 1 & 2.Sounds like fuse 9 or 10 is a good source too. 16 amps.
Side note - would you happen to know which wire runs to the horn (is it yellow with black dots) and is it positive (assume so, but who knows?)
I don’t have a live battery at the moment
78 Fiat 124
The wire diagram shows a solid yellow wire supplies power to the horns. This wire comes from the horn relay. The steering wheel horn button supplies a ground to engage the relay. When the relay is engaged power is supplied to the horns. In other words the horn power wire only has power on it when t he horn relay is activated.would you happen to know which wire runs to the horn (is it yellow with black dots) and is it positive (assume so, but who knows?)
You are looking for a wire that has power only in the "start and run" positions of the ignition switch. I thik you correctly mentioned earlier it could be the Pink wire or the blue/black wire coming off the ignition switch. If you have an original Sipea ignition switch there is often a spare "INT" terminal on the switch you could connect a new wire to. The "INT" terminal is a "hot in start and run" terminal.
You anwsered both my questions! Thank you!spider2081 wrote:The wire diagram shows a solid yellow wire supplies power to the horns. This wire comes from the horn relay. The steering wheel horn button supplies a ground to engage the relay. When the relay is engaged power is supplied to the horns. In other words the horn power wire only has power on it when t he horn relay is activated.would you happen to know which wire runs to the horn (is it yellow with black dots) and is it positive (assume so, but who knows?)
I was looking to wire my new horn - after cutting a completely mess out of my engine bay.. and he second question was the run wire.
Thanks a bunch! It’s hard to do without a running battery!
78 Fiat 124
